M mac Well-known member Joined Sep 3, 2007 Messages 3,558 Reaction score 791 Points 113 Dec 3, 2013 #1 Have a hydraulic pump unit that just isn't putting out the pressure that it should. The gauge shows around 200 psi. Fluid level is fine, and the motor and pump sound normal. Any thoughts?
E Earl Weiss Well-known member Joined Aug 31, 2007 Messages 6,342 Reaction score 926 Points 113 Dec 3, 2013 #2 Is there a strainer or filter on the suction side? Could be clogged. Change filter or clean strainer. Strainer could be inside the tank under the oil. A pump could be bad, bypassing internaly and sound good.
Washmee Fullservice Tunnel Joined Sep 3, 2007 Messages 973 Reaction score 2 Points 18 Location Canton, Ohio Dec 3, 2013 #3 Is it feeding a flow divider? Where in the system is the pressure gauge?
