It depends on whether or not you have needle valves on the system. I always use them, and I prefer to run about 70 PSI on tire cleaner, 80 PSI presoak with the air pressure 5 PSI higher on each. No needle valves on presoak liquid, and the air valves cracked just enough to slightly aerate the presoak. Tire cleaner liquid is throttled back quite a bit and more air to create a thick foam to stick to the tires.
One of these days I'll put a flow meter on them to aid in adjusting without walking back and forth to the bays and to better see how much product is actually getting used.
