I just replaced my 2 membranes due to a permeate flow drop. After replacing membranes the flow rate increase to the maximum gpm (2.5) which I need to keep up with production. Today(1 month later) I checked permeate flow rate and it decreased about .5 gpm.
System makes 2.5 gpm permeate max or "3600 gpd"
Maximum pressure threw membranes = 200 psi
Current pressure = 150psi (pressure can be reduced but cannot reach 200psi)
I tried adjusting the regulator to increase pressure but the regulator cannot go any higher than 150psi.
My question, is my regulator the problem or is it my pump(procon). The owners manual says if a 200psi pressure cannot be reached and flow rate is not maxed out "2.5gpm" the pump might be losing efficiency.
Any advice ?
Any advice ?
