LW 4000 Gallons per wash
MDrost1
How many gallons of water does a laser wash use per wash. My top wash uses:
Presoak
Lp soap with bug prep
Hp rinse
Lp wax
Hp polyseant
Spot free rinse
Thanks!
What size nozzles are you running are they worn out, 2505 or 2504 or both. What speeds do you have everything on like Rinse speed 0,1,2 all those play a factor in how much water you use.
Go to the Water meter at the road at night at your carwssh when no one is washing there car and make sure no water is on anywhere mechanical room ect, and wash your car. Pay attention to the meter for gallons of water this probably would be the simplest option just has to be dead at your Carwash when you do this. Might even close it off at the road for 20mins wouldn't hurt. I am sure someone else on here could tell you another option also.
I change nozzles yearly:
https://www.kleen-ritecorp.com/p-3825-pdq-laser-4000-nozzle-replacement-kit.aspx
Here is the overview. Do you think it is over 40 gallons of fresh water? I have the GinSan RO system that reuses reject water. Everything is operating to spec. Undercarriage runs for 3
Undercarriage Spray ON
Soap Type: High Press Rinse
Dryer ON
Bug Prep ON
Rear Bug Pass OFF
Cycle 1 Disabled
Cycle 2 Low Press Soap 2 Speed-7
Cycle 3 Low Press Soap Speed-7
Cycle 4 Soaking
Cycle 5 High Press Rinse Speed-4
Cycle 6 Foaming Wax Speed-7
Cycle 7 HP Polysealant Speed-9
Cycle 8 Spot Free Rinse Speed-7
Cycle 9 Disabled
