Folks,
I noticed the plastic elbow that connect the conduit to the passenger side sonar eye box was disconnected from the box this afternoon. I also noticed a small crack in the elbow(it is plastic). I reconnected the conduit, dried out the box, and taped the elbow up with "plumbers fix-type" rubber sealing tape. The connection at the box is solid and seal seem ok, but not a permanent fix.
I am wondering if the part is PDQ specific or can I pick it up at a local hardware store? What part should I be looking for? Does the sonar eye wire need to be pulled to put a new elbow on? Or can the eye be disconnected from the wire from the sonar sensor and replace the elbow? Looking for some advice and would like to know if I need a visit from one of the techs or if it is something I can do. Thanks!
