LW 4000 tire and tube change?
MDrost1
Grand Haven, MI
LW 4000 owners,
Do you change your tubes/tires on a preventative maintenance schedule or do you wait for them to blow? Looking to find the best method for staying on top of tire issues.
PEI
Danville, VA
I change tires when the tread wears out. I change tubes when they go flat and want hold air. We used to patch the tubes, but it really isn't worth the extra hassle. I do monitor the air pressure on a regular basis to make sure they are holding air.
BBE
USA
Contact Jamey Turner for a set of no flat tires for your laserwash. They have no tube in them, yes it can be difficult to get them on the rims at first until you figure out a good method, but you won't have to worry about anymore flat tires. If you have double doors you should be fine to run them all year round. We have double doors and run them year round without any problems. If you don't have double doors and it gets down in the teens inside of your automatic, you will want to go back to the tube tires in the winter.
PM me if you want Jamey's number. They aren't very expensive. We've been running them for 3 or 4 years no problems.
