LW prox switch Cable, from K-R...?
does anyone know if K-R has the cable, that hooks up to the 12mm prox sensor? If so, part # . I can not find it
also, what about the festoon (Black belt loking thing) that goes on the top row, running along the bay
sparkey
Prox cables are pretty much all the same. I see kleenrite has a 5 meter cable part number IFMC001. You could probably get a cable from automation direct for less than half the cost.
HOLY $HIT! I looked on their website, for 30 minutes, & was so confused with alllll that they had!
Mansfield ohio
Do you have the link to the 12mm eyeys from automation direct thanks
and the 30mm shorts
and have you ever purchased a gear box or motor for the 4000
I use automation direct prox cables, I use one with an orange jacket that is steam cleaner rated . no issues.
pgrzes
S.E. Pa.
Can you guys add some links? I usually get prox's and the cables from Kleenrite, they are much less expensive then the distributors, but still expensive. Also if someone else has gear box options for laser & washworld that would be great as I feel they are well overpriced.
