Need help identifying the unloaders/regulators on the LW4000 - newbie ;-)
I see 3 unloaders on the (vertical) pump stand (picture below). It's obvious that one is for the LP and one is for the HP. What's the third one for ? It's got a leak. I took it apart - awfully dirty inside, cleaned it up but it's still got a leak.
I'd like to replace it. The PDQ tech told me it's 53.3 GPM. The closest one I found at KR is this one : http://www.kleen-ritecorp.com/p-1780-kleen-rite-balanced-pressure-regulator.aspx
Is this the correct one ?
Also, the LP on one of my bays doesn't get over 120psi (all LP cycles). Other threads indicate that 175psi is ideal. I'll change the gauge this weekend, and then adjust the unloader, but what else should I look for ?
Where can I get a replacement LP unloader if I need to change it ?
Any help appreciated.
