I had a prox issue, on x16, rear / front measure, & bridge slammed into entrance so hard it bent the metal stopper. Heck, it nearly flew off the rail! Ha.
After that, the hp hose kept hanging up on the floor mounted frame, on return home. I could NOT figure it out. PDQ couldn't figure it out, although they were on ph & not there to see it.
I shot it down for a day, prayed, went back next day.
Was such an OBVIOUS & SIMPLE fix. Hose was turned wrong way, & that was cause it to jam up on frame
Simply put hose all the way over to drivers side, on return, & no more problem! Thank you Jesus!
