Making Simoniz "Correct" foam good
I have 2 preppers who have cars clean b4 entry. I know, costs a lot, but that's the business model i inherited.
To keep chem cost down, I use Correct as my PS. What would you guys suggest i add, to make it foam really good? Would like it to be CHEAP.
We wash about 45cpd & about 4 cars at night, so want it to clean @ least a little bit. Nearly all those cars at night are somewhat clean, cause the town knows the deal...
I use 1/3-1/2 a bucket of Simoniz Foam Additive. It’s cheap and foams good as my SS HP soap.
If you want a color or scent just use a dual tip injector and pick whatever color and scent Foam Brush soap you want. The Correct does the cleaning and anything you add to it is just for show (color/scent).
I use JBS Storm as my SS presoak and use a dual tip hydrominder to add JBS blue FB soap using a very small tip, either pink or purple. It doesn’t take much to make it very blue.
We sell a product called
so youre mixing a low ph or ph balanced product with a high ph presoak?
That's up you. Suds Price it comes in 55 gal . Its for the auto pre soak pass right. You have a mixing tank with a spinner. Or is the correct for the pre wash before the auto . Ether way,, is does an potency to. Kleen rite stocks it.
If you want the “Correct” to foam like Eric said add 2 gallons of the Simoniz Foam Additive #PA5552, it’ll foam like a bastard. I’ve been using KR “Super Wash” as my self-serve Presoak and I’ve been real happy with it, it has some surfactant in it so it foams up pretty nice. The “Super wash” has a PH of 13. I couldn’t find the PH for “correct” on the SDS sheet. I have a Turtle Wax dual tip metering block on my Foam brush Hydrominder and I’m pulling a little bit of the “Super wash” in with the Foam brush soap to give it a little kick.
Great ideas
You could use simoniz MC Plus liquid from KR. It is a booster with added cleaning power. I use it through a dual injector since some chemicals wont stay mixed with Correct. It adds butyl and dilimolene along with foqm.
