Mark 7 Aquajet GT700 error code F30
Paproskisteven12
I have a a error code of F30 ( low water pre soak tank) but my pre soak tank is full. Also using my controller the last error code is F5 I have know idea what the f5 code is. Any advice?
Keno
Check the float switches in the pre-soak tank - we have to replace every year or so. They don't last in the hot water.
Keno
Did you put the bottom switch back in the correct orientation? Easy mistake to make. The top and bottom are opposite as far as the float travel if I remember correctly. The bottom switch is the "check" to make sure there is water in the tank, the top is the fill switch
Keno
Error F5 not in the manuals I have, can't help with that.
Paproskisteven12
You were right I had the bottom one upside down
Keno
Good deal, hopefully you salvaged some of your weekend business.
We have found the bottom switch usually goes out first since it's submerged in hot water 24/7, and we replace both at the same time because the top is usually not far behind in failing.
