Mark Vii GT700 Error
Kdavid35
Put in new PLC because we were getting an F code on the display. Once replacing the PLC, we got power back to it and now get a F30 code and nothing will reset or run. The presoack heater tank has water in it, so not where to go next..... Any help would be greatly appreciated.
Low water presoak tank is F30 error. Is this a new or used plc? Is the PS tank filling automatically or did you manually put water in? Not sure how the tank level is measured, but if it's a Madison float switch like the 300s, those go bad a lot, easy and cheap to diagnose and change those float switches. KR stocks those switches
What was the original F code before replacing the PLC? What is the description of that code?
Now, if you have water in the Presoak tank, check your input led and voltage, maybe the cable was not properly conected after the PLC replacement.
