For those who have had experience using Methanol Foam Brush solution during the winter months please provide me your thoughts/recommendations:
Understand that the biggest advantage is gas & water savings as a result of shutting down the trickle?
Is the quality better or worse?
What problems have you or your customers had with it?
Does it really work and at what temps? Does it freeze?
Which brand do you recommend?
Is more foam brush solution used than normal?
Would you use it again and why?
Kidwash
Kidwash
