Microcoin QL and Vacuum Timers
copperglobe
Anyone know what timer for a vacuum works with a Microcoin QL? It won't work with the IDX and I'm told it won't work with Ginsan. The Microcoin requires more power than the IDX and Ginsan can handle. I'm told that in order to use a Microcoin in a vac you need to add a small 24v transformer to run the Microcoin. Thanks.
That's odd we have the Microcoin QL's in our J.E Adams vac's with a IDX AT-411 timer and in the Fragramatics combo vac's with no problem.
We've tried running the AT-413 IDX timers and they won't work with the Microcoin. Wondering what the difference is between the 411 and 413?
Update: Looks like the AT-411 requires a separate 24V transformer to run the microcoin where the AT-413 has it's own 24V transformer but that transformer isn't big enough to run the Microcoin.
