Microcoin QL mounting faceplate options.
1carwash1
east japip
Will the Microcoin QL insert (actual acceptor) fit into any other mounting faceplate? The JE Adams website shows a Microcoin QL mounted in an all stainless faceplate. The faceplate they use for this seems to be similar to the IDX faceplate.
I tried putting in just the insert into an IDX frame (IIRC) and it looked like a drop in but is too fat. The frame would have to be cut out for the QL insert to fit.
1carwash1
east japip
Thanks, here is the JE Adams link i was referring to.
cantbreak80
Maybe I need new clubs
CO
That's an old photo.
The QL bracket was redesigned many years ago.
It features locating holes for the acceptor's pins and the retaining strap slides down and snaps in place. No tools required.
Check out the pics on my provided Kleenrite link.
Mchas
It actually will fit into the IDX frame but you have to unscrew the screw that holds the bottom of the frame together, and slightly bend it down. It’s a much better frame than the plastic junk that the Microcoin acceptor comes with.
