Monex on Wash Select II
Sselby
Hey everyone,
I’m trying to retrofit a Monex Credit Card terminal on a Unitec Wash Select II via pulse. Monex and Kiosoft have sent me diagrams, but I still get an error on boot up. Can someone clarify how this should be wired in?
Keno
I have 0 experience with Monex, but you will probably get more help if you post the diagrams, what you have done, and your error. monex can’t help you with the error code you provided them?
Sselby
Here’s the diagram + the error. It seems very straightforward, outside the blue wire only says to utilize Pin 5, not J1 Pin 5. Is there a standalone Pin 5?
Fatboy769
Living the American Dream
I’m pretty sure coin 2 is on J9. Should be at the top of the board that shows the 4 wash prices and names.
mgs
Mark VII Distributor
Gaithersburg, MD
I believe the error you are getting is because the "Kiosoft terminal" is looking for the VMC (the controller on MDB communication protocol), so, to me, I guess, the Kiosoft terminal is set up in MDB mode, waiting for commands from the VMC
