Money Manager on meth
Jimmy Buffett
My MM has gone insane. With nobody in the wash I can watch it click off $8 every couple of seconds. It says my vacs have done over $200k in the last week. I cannot make it happen by putting money in anywhere. I tried to update from the JC site but it may or may not be functioning due to the hurricane. The guy at JC said that they would call me back but have not yet. Anybody have any suggestions? I really miss it!
Jimmy Buffett
No I don't have an $8 or a $9 price point but it usually comes $8 or $9 at a time. It's adding it all to vac income but I can't make the vacs do it and often it happens when noone is around. I looked once this afternoon and it was at $1350 and lookded later and it was only $500 so it either goes backwards or cranks up high enough to start over.
It's supposed to be reading pulses off the coin acceptor. I would disconnect one vacuum at a time to narrow it down.
Jimmy Buffett
Well I found my problem. It was in my shapooer and I had a slow drip coming from that little plastic bowl. It was dripping right down on to the sensortron and apparently shorting out the mm. The coin acceptor was malfunctioning also as occaisionally you would get 12 mins. for .25. Oddly enough no one brought this to my attention. I replaced the sensortron and everything was working fine but the mm. I ended up just unhooking it. I guess I'll give it some time to dry out and then try to hook the mm back up. Thanks for yopur help!
Jimmy Buffett
I emptied the quarters out yesterday. I really thought $494,000 worth of quarters would have been heavier.
Jeff_L
Darn, no more 12min vacuums at Jimmy's place. Going to have to find another place! :)
