Multi-Use Regulator
It needs to be able to handle the something-like 2200 PSI from the CO² cylinder. That's why the proper ones are so expensive.
I already have the one attached to the cylinder already, I want to use these ones for balancing the pressure in each keg individually. The maximum pressure I would potentially feed these with would be 20 psi...but depending on the style of beer, some need more, some need less. Do you think these would work in this situation?
I don't know, maybe they're food-safe or super accurate, but it seems like any decent regulator will work.
