Need a technician
I have a 6 bay self serve car wash in Killeen Tx. However l haven't been able to find someone that can help me fix one bay. The clock keep displaying Error and lt does do anything. I have a 8 switch rotary switch. Anyone knows someone that can help me with this? Thank you so much in Advance! Blessings
When you say your "Clock" is displaying an error you must be talking about the TIMER! Do you know what brand of Clock/Timer you have? Can you post a picture of the back of the time Clock/Timer? This is someone you can replace yourself.
You have the best techs money can buy right here on the site....if your willing to try to fix it plenty members are willing to help.
Post pictures and tell us what it's doing and I'm sure you will get some responses.
I had this problem last year. We have Dixmor 6 timers with Crytopay. I had to disconnect the pulse wire from the swiper and it resets itself. It's my understanding it's the pulse circuit causing the error code. It was on mine.
What kind of timer board is that? Try disconnecting the coin acceptor from the timer and see if it still says FAIL. If when you disconnect the coin acceptor and it doesn't say FAIL then you know it's the coin acceptor that is sending a constant coin pulse to the timer.
