Need chemical help!
TEEBOX
It's been 1 year since I installed a wave curtain in my tunnel. I used a lo ph shampoo in it to balance out my hi ph preasoak. I have since moved the lo ph feed further down in my tunnel before my wraparounds. Cars are coming out cleaner and dryer.
Also, by doing this it saved me a lot of dollars because of the cost of the lo ph shampoo.
I'm looking to put a high foaming neutral for my wave curtain for the show... Does anybody out there recommend a high foaming neutral?
Most chemical companies should should have what you are asking for. The use cost difference between the best and cheapest should be relatively minor so go with what works best for you without worrying too much about the cost.
