Need help programming timers for a shampoo/vac.
topjimmy17866
Penn
I am posting this for my brother He has shampoo/vacs that use 1034r timers. One of the shampoo/vacs is having issues with giving out the correct time for the vac. We programmed it to what the other "good" shampoo/vacs settings are but it seems to not be working properly. The run time isn't the same. He never really had a good set of programming instructions for the timers and we basically set them up on the fly. He also has a couple of other backup timers . Those are CT- 2040 & CT - 2050. He has no instructions for those at all. We switched them out with the 1034r to see if it was the issue but I couldn't figure out how to program it at all. Is there a place I could go to to find the programming instruction that would be greatly appreciated. Also I believe I saw that the 2040 & 2050 are older model timers then the 1034r. Is that correct ?
Tom Thumb
Orlando,Fl
topjimmy,
If you will send me a PM I will forward you a copy of the instrution for the 1034r.
