Need help with our PDQ Lazerwash 4000
mparker1975
winchester va
For the past few weeks we started getting a low water in main tank error. I followed all the manual suggestions and finally decided to change the low water switch. One day later the same error code came back so I personally watched several washes and could never get the fault. The fault seems to only happen when no one is there (frustrating). The tank appears to be filling properly and not causing abnormal turbulence in the tank. Does anyone have any suggestions. FYI, this PDQ has a bit of age to it and has been used quite frequently on a daily basis.
I thank you for any help given!
Mark
