Need vac vendor
Eviltoad
I am in the dental lab industry and I have seen non-coin operated vacuum systems at carwashes where there is a central vacuum and PVC pipe is ran along a length with the vacuum hose coming off that pipe. I would like to do something similar with the unit to be placed outside and a run of about 20 feet going inside the building and then coming off the pipe there would be three different suction stations. Could someone point me toward a vendor that may be able to help me? Thanks in advance.
Kendall
Kendall
http://www.sonnysdirect.com/pc-368-39-central-vacuum-systems-separate-mount.aspx
http://www.spencerturbine.com/products/vacuum-cleaning-vacuum-systems/car-care-vacuums/default.html
http://www.auto-vac.com/
The type of vacuum you would need depends on what you are wanting to suck up and how much of it there is. Given that you appear to operate a dental lab, I would guess that your debris is very fine, and rather low in volume. Also, it is important to know if you are only ingesting dry debris, or do you also have to ingest liquids?
