lilb93
The pumps are 310 cats with 5HP Balador motors. The Nozzles that are on are 1507 MEG. Have the pressure set at 1300 PSI.
When they do not pull the gun handle in the bay the pressure jumps to 1900 PSI. when handle pulled it goes to 1300 Appx. Is that normal??
Only on one bay I could turn up the pressure to max (Unloader all the way down. Max pressure 1100 Psi When you do not pull the gun it jumps to 2200 PSI Changed the tip or nozzle with a new one no difference. Has me stumped..
