No 24V power
white32
Houston
With the help of this forum, I have worked out most of the bugs I was having with timers previously. However I have one bay in my Ginsan Champion system that has no power to the 24 volt circuit. I have replaced the bay timer display, the relay (GS27), and the inside timer (GS 255-->401/402). There is no power to any of the terminals of either the relay or the timers according to a voltmeter test. The high voltage circuit is working for that bay as the motor and pump run when the switch is pressed.
Any ideas on what to try next?
Thanks,
John
Keith Baker
Keith Baker
Omaha, NE.
I'm not familiar with your specific system, but it sounds like you need to check for 24v power right at the transformer. If you have it there, then check the fuse on the hot side or check for an open on the ground.
white32
Houston
It was the fuse-thanks! I didn't realize there was a separate fuse for the 24 V system.
