Hello- The high pressure pump on my Laser 4000 will not kick on when undercarriage is triggered. The Lex air valves are changing over and I can manually kick on the hp pump in test mode. What should I check or look for?
Also, sometimes when the Lex air valves change over it sounds sloppy like water is interfearing. I put a rebuild kit in both, so what might be going on there as well?
Thanks in advance!
Thanks in advance!
