So I had a customer complain about the pre soak in one of the bays. Checked it and sure enough just a little trickle when turned on so I checked the other 5 bays and the same thing is happening. I checked the solenoid block and no 24vac on any of them and the pumps never turn on either that draws the pre-soak into the pump. Since all are doing it is it possible to lose a common wire and would that cause it ? Why are the pumps not turning on? Still looking at wires.... anyone else ran into this?
