No pressure
DAWGWASH
I have Jim Coleman SS. When I Sm on rinse cycle the cat pump has great pressure. When I turn soap, wax, or pre soak I have no pressure on the cat pump. Just on one bay. Any idea. I changes the rotary dial. Nothing. The motor cuts on and runs on the cat pump but doesn’t build up pressure
Lexington, Ky.
those functions get water from the tank. Check your check valve for that bay going to the holding tank.
It's very likely the check valve under the tank. Those can be "fun" to replace, but if it looks like you have to take them all off, there's a shortcut. Cut the fitting off right before it and add a union. I worked on one that didn't even have ball valves on it, and I thought I was going to have to shut the whole wash off for most of a day, but after the owner cried about lost income I managed to only have it down for about fifteen minutes while I cut out the bad check valve and added a ball valve so I could work on it. At least it was 170° degrees in the room because his 2 million BTU boiler wasn't vented to the outside.
It could also be one of the tubing lines that go into the manifold under the tank, or a bad fitting at one of the soap, wax, or presoak solenoids.
DAWGWASH
It was a check valve. Gotta love that one. Thanks for the info
