No Softener in Automatic
wash12
If your softener goes out can you truly get RO water? Hardness out of city water is about 5 grains. The site has been running it this way for over a month is this going to cause damage to the RO system and will it actually truly produce spot free water?
How would I test the RO water to see the quality is there a kit online I can buy?
You can get ro water but your ro unit will not last as long. It will scale up.
An operating softener would allow your chemicals to work more efficent.
You need a TDS tester to check the RO quality. Most say it should be below 50 PPM to be truly spot-free, but in my experience it's not good over 30. You should get good quality RO on hard water but it will always be a little better with soft.
Hard water will foul your membrane(s) faster, but at 5 grains it may be a minor difference. You might consider a small softener just for RO pretreatment or for everything except high pressure on bays and auto, or track how long the membrane(s) last on hard water.
Why add a Softener if not needed? Most water utilities will give you a report on water quality and most will give you historical data. You can also sample and get tested a pool supply store. if water is already "soft" and low TDS why fight it. Consider yourself fortunate.
Ok I was way off on this I was going off what a chemical rep told me, I bought a kit and tested it and we are at 13 grains! Does this change everything?
Yes. 13 grains is pretty hard and can mean you need up to 50% more chemical to do the same job as soft water. Your membrane life on the R.O will be dramatically shortened also. You need that softener!
