Non powder presoak or…
Bricks
Has anyone used powdered presoak in their IBA and then switched to something like Blue Coral high ph?
Do you use less, or are you just spending more? Are the cars just as clean with powder?
I used to use a powdered presoak but I went through it way too fast and I was mixing constantly it seemed. Once I got my new razor I switched to high pH liquid concentrate that my distributor sells. It works great and I wouldn't change a thing.
Bricks
Is yours $493 for 20 gallons? Do you use a brown hydrominder tip?
it's called select plus. it's hi ph. no idea what tip. my distributor set it up. set it and forget it!
What is the cost per car for a double pass of presoak? My powder setup I am using is still under .50 cents per car and no complaints.
