Offer to Change Out VendMaster and Vend-It Units
Uncle Sam
California
We asked for input from Forum members and studied both a Vend-Master & Vend-It unit in-house before we designed and built our ShurVend Half-Pint vendor to incorporate the Forum member inputs and overcome the flaws that have been posted on the Forum. We have utilized established technology to build a unit that has ?Guaranteed Delivery? as a unique feature in a small vendor.
The used Vend-Master/Vend-It units are like trading in a Yugo; we do not have a use for them. But the existing bill validator and coin changer in your Vend-Master/Vend-It may be a usable MDB** version (worth about $600-$700) which we can install in our Half-Pint small vendor, frontload (FL) or rearload (RL). We realize that all of you have invested considerably more into your Vend-Master/Vend-It units than what we can offer you, but technology makes older equipment obsolete very quickly. At least you can recover some costs while changing to a new unit with credit card capability, less work ?tweaking? product packaging, and gaining peace of mind about your vending.
Here is our offer for direct sales to Vend-Master/Vend-It owners: We will install your working MDB bill validator and coin changer (which you send to us from your existing Vend-Master/Vend-It unit) into a new ShurVend Half-Pint FL or RL unit. We will cut a narrow, precision slot into the stainless door to install your bill validator so we can maintain our Half-Pint?s Hi-Security features. In addition we will give you a cash allowance of $500 off our list price for the front load or rear load vendors. If you haven?t seen our small vendor before, you can see these ShurVend units at the WCA show (September 22-24, 2008) in Las Vegas at the Bally?s Convention Center where you can ?kick the tires? before deciding.
This offer will be honored through October 30, 2008.
Cont?d
Uncle Sam
California
SPECS:
The ShurVend Half-Pint FL or RL requires a hole that is 32 ?-inches wide by 46 ?-inches high. The FL and RL “footprint” into your equipment room is 28-inches (if you have an 8-inch block wall) because the vendor trays are a full size 24-inches long. In addition the rear-load RL vendor needs space behind it to pull out the trays, pull out the service chassis, and stand behind it to service. The hopper (drop box) in both vendors is the same size as the free standing vendors and the clearance between the tray and the window is over 8-inches so the taller car wash packs vend very well.
Warranties will be the same as a new ShurVend Half-Pint vendor except for the bill validator and coin changers that you send to us.
**The way you can tell it is MDB is that both changer and validator have 6-pin male and female plug harness with 5 of the 6 plug holes with pins (wires) in them. One is blank.
Uncle Sam
jimholve@big-eagle.com www.shurvendplus.com
