Old ryko Voyager Problem
nicolwash
Austin mn.
Hi Guys, my right rear tall brush is coming in to hard on the cars the left one is fine.I had a ryko tec. here for 9 hours with no results so i thought i would ask the real pros.. By the way its a 1989.told you it is old. Thanks
Bill
Ryko CS
Grimes, Ia
On the output of the rear pressure regulator and arms in valves, the air is tee'd to both rear arms. Provided your pressure is set to a normal range, it sounds like your right rear arm may be out of level. If you remove the air to the rear arms, if you place the right rear in a position where it is almost all the way out, does it stay in that position without air, or does it fall toward the center more than the left? Bring the arm all the way in to the center and do the same thing. Does it fall heavier either in or out? Both arms should react similarly. If the right falls in, place a jack under the brush, loosen the pivot bearing bolts slightly to slightly counter the direction of fall. Retighten the bolts and check again. This should provide a more balanced action of the rear arms closing.
nicolwash
Austin mn.
Special thanks to Darin from Ryko for his help to solve my problem, We had replaced the right rear brush motor a few weeks ago and the electrician wired it to spin the brush the wrong way causing it to come in to hard. Bill
