One of the headlines on AOL today
JMMUSTANG
car wash owner
at the car wash
Can Automatic Car Washes Damage Your Car?
Keep These Tips In Mind To Protect Your Ride (And Your Wallet)
Posted: Jun 30, 2010 | By: Eric Peters
Jimmy Buffett
I like where he suggests that they bring their own bucket and rags to the ss. What a dumba$$.
It's been "headlined" on AOL a half-dozen times over the last year. Each time there are a lot of comments that it isn't very accurate.
Red Baron
Idalou, texas (near Lubbock)
I'd be tempted to run an ad using these exerpts:
Here are a few important things to keep in mind when it comes to automatic car washes:
Be sure it's "brushless" -- Some older car washes still use abrasive brushes (instead of cloth), which can leave small scratches in a car's finish. On older cars with so-called "single stage" paint jobs, light scratches could usually be buffed out; but all modern cars use a "base/clear" system with a thin, transparent layer of clear coat on top of the underlying color coat to provide the shine. Once the thin clear coat is damaged, often the only way to restore the shine is to repaint the damaged area.
Another safe bet is "touchless" car washes that use only high-pressure water jets and detergents to clean the car -- without physically touching it at all. There is virtually no chance of your vehicle suffering any cosmetic damage this way. Some areas have "self-service" coin-operated hand washes, which are great for spraying away heavy dirt buildup. You'll usually need to bring your own bucket, wash cloth/sponge and dry towels, though.
Watch out for the after-wash wipe-down -- Most drive-through washes use a strong jet of heated air to force excess water off after the car goes through the wash. Many full-service car washes will then have you drive the car (or drive it for you, in some cases) away from the wash area to be hand-wiped by attendants. This is usually OK -- provided the attendants are using fresh, clean (and soft) towels to do so. Be alert on busy days, when lots of other cars have gone ahead of you. If you see the attendants using obviously dirty old rags to wipe the car down, you should say "thanks, but no thanks" -- and drive away wet. Dirt and other abrasives in the rags can scratch the finish just like sandpaper. Simply driving away from the wash and letting air flow over the car to dry any remaining water won't hurt anything -- and is the best guarantee of a no-damage experience. Any lingering streaks can easily be cleaned up at home yourself using readily available spray cleaners designed for just this purpose. (Honda Pro Spray Cleaner & Polish is excellent for this; it also provides UV protection and easily and safely cleans off bugs, tar and road grime, etc. without water.)
Washmee
Fullservice Tunnel
Canton, Ohio
I don't use "Rags" to dry off anyones car. I use expensive towels that are constantly washed in an expensive commercial washing machine. That recycled article is so full of half truths and misleading info its really a joke.
