washnvac
Got a unit where all the products from the solution pump and sf pump are running back through the under carraige. Since there are no check valves on either the hp or u/c line out, I assume it is one or both of the lexair valves allowing the product to scoot around those valves. I guess there is no check valves because I could not locate an hp check at 1 inch with hp capabilities. But that would keep the back pressure off the lexair valve. I guess I could reduce to a 3/4 inch check.
Still on a learning curve with this place I bought at Sheriff's sale.
Thanks in advance for any help.
