PDQ stainless check valves arent all stainless
Sparkleclean
I have PDQ g5 units and they have stainless steel check valves (3/8"m o-ring x 3/8" m-jic) that are located on the input side of the soap heaters. in some g5 models they are on a small manifold block just before the heaters. I have noticed lately that I have been replacing these things a little too often in the last year or so. especially being stainless. they aren't cheap from PDQ either, around $60 each. I had a problem the other day, I had previously used one of these things on my main water manifold in my pumpstation because of a separate problem PDQ has with their chem solenoid valves, all of a sudden my pressure for soap 1 skyrocketed causing water to pour out of the unloader onto the floor.
as it turns out, the culprit was one of the two tiny little loop portions of the "C" clip that is used to hold the internal components of the check valve inside of the body that had corroded and broken off and got wedged into the nozzle for the injector. those are the loops you insert the tool into to remove the clip if needed. that caused the pressure to rise. no big deal, I fixed the problem and everything was good. but I realized that every time I have changed one of these things the C clip is missing. and the internal components like the spring and seal are still floating around there, but once the c clip goes the check valve is worthless.
I realized that the c clip itself was not stainless steel. when I removed one it stuck to a magnet. these are supposed to be the checks used on the corrosive soaps, and the most important part is junk and quickly corroding away. I cant find another source for these besides PDQ so I'm stuck buying from them for now, but I'm wondering if anyone else is having this problem?? what is the point of a stainless check valve that is not completely stainless.
A follow up to this....
I emailed the pdq engineer today about this and he responded that after checking their current on hand supply he found that i was right. The c clip used on these check valves are either not stainless, or not the kind of stainless they should be. They have used these valves from this supplier for a long time and are checking with them to see what is going on. He offered to cover what i have under warranty but obviously i have to wait till he figures out what is happening with the vendor first as all they have are these non stainless valves in stock.
This has been an issue longer than you think. They released a product bulletin in March about check valves not having a stainless pin. Now this may not be the same check valve, but it is nothing new.
Can you say "made in China" ? This has been an issue for years. And for things like this there is no need to go through the manufacturer. Buy em online and have enough left over for a nice meal.
