Power Tower for WW Razor
washregal
Have any operators invested in the power tower for this unit - Just curious if it does anything for wheel cleaning as it is toughted. Not sure how an IBA might be able to clean wheels effectively especially since the car rolls by it. Any advise on if I should back off on buying this option with my razor or should I get it - ?
Get it if you want to separate yourself from others. I got them when WashWorld came out with them about 4 years ago and put them on my laser. positive notes they do clean and people love them. Only negatives is you will have way more dirt in the corners of your bay to clean up like they pull a lot of dirt off the car into the bay and you have to change the nozzles once a year because the spray pattern will not be a tight circle use more water and the hydro flex rebuild kits suck and are only about $10 cheaper than a new nozzle and the blue foam covers are not cheap to replace. Besides that there great and i haven't seen nothing to compare them too. In the winter when it's extremely cold I have had issues if weep is not set really strong.
I have them on my laserwash too. I wouldnt have an automatic without them. Do not give undercarriage on your cheapest wash. The power towers are so good they will all buy the cheap wash. And definitely dont walk in front of them or stick your hand out in front of them. It will take the skin off to the bone
