Pre-Cast Concrete Roof in IBA Deterioration
MDrost1
Folks,
I have an IBA with 5 SS bays. I installed doors on my IBA this past year and used them successfully through the winter. However, I noticed this spring/summer that I was getting cracks and chips in the pre-cast roof on the interior of the bay. I can't verify that the excess moisture in the bay, due the new doors, was the cause.
My question is: It there a way to curb this deterioration? A product I can apply to the ceiling in the bay to protect it from heavy moisture and the IBA environment? Right now I am chippin loose concrete and spraying the affected area with a silicone spray for protecting. Kind of new to this, so thoughts and advice are appreciated.
Thanks!
There should be several epoxy paint products that you can use. That would seal it up. Don't know though it the damage is from moisture.
