copperglobe Active member Joined Dec 24, 2007 Messages 427 Reaction score 57 Points 28 Location Rocky Mountains Oct 23, 2014 #1 What kind of pump are you using for the pre-soak in your automatic? Thanks.
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,665 Reaction score 3,949 Points 113 Location Texas Oct 23, 2014 #2 Running a Belanger Vector, which uses dosing pumps to mix with water downstream from the main high-pressure pump. Used to service D&S 5000s that used a booster pump such as this:
