Was curious as to which way to plumb a prep gun would be best. By this I'm referring to wether the pump is controlled by a flow switch or stays on via timer or on/off switch, or the pump stays on and the return goes bach to a tank. I want to put in a system that I can walk away from and not worry about cooking pumps or overloading the starts per hour of an electric motor.
