J joedirt New member Joined Feb 14, 2011 Messages 11 Reaction score 0 Points 1 Location Toledo Ohio Aug 18, 2011 #1 Can you high pressure wash a diesel engine the same as a gas engine?
jfmoran Active member Joined Nov 28, 2007 Messages 328 Reaction score 64 Points 28 Location PA Aug 19, 2011 #2 Just be sure to cover any air intakes, plugs or electrical areas that may get fouled if sprayed directly with water. We use plastic grocery bags and large rubber bands. Obviuosly, you do not want the engine to be hot when you put the bags on.
