I am still fighting with my prewash operations.
We were using dawn when I took over the wash and everyone on the forum tells me its not good to use.
I have been trying different options that my chemical rep has been providing and have not found a good alternative.
The best product we have used so far is a powder based chemical called a drum pack. We have been putting it in the spray guns and wetting down the vehicle as well as putting a handful in the brush buckets when we change the water.
I have two problems with this product.
One is that unless the vehicle is kept wet it dries quickly and leaves bad streaks that the in bay does not take out.
Two is that it is costing me about $.20 per car. We think we can stretch it to a month but even then its $.10 per car which I think is way to high.
One option is to increase the pressure that is going to my prewash guns. Right now its pretty low, just enough to get the cars wet. If I increase the pressure I could use less soap.
here is what I have now
Can I just put a higher pressure pump or would I have to run new lines to the guns?
What type of soap would ya'll recommend I try for my prewash soap?
