Uncle Sam
With reference to V-Blog #43 and the Vending Formula posted below, the #1 priority for most operators is the security of the multi-vendor from vandalism or theft. The word “window” almost always gives operators (and vandals) the perception (as any window would) that this part of the multi-vendor is vulnerable, so the multi-vendor is usually positioned on the wash site in a “very public place” to minimize exposure to theft and vandalism. Real world experiences verify that this “perception becomes reality” because the first thing attacked by vandals on a multi-vendor is the window. Whether it is throwing concrete blocks, bricks, large rocks, or trying to kick the window loose, we have seen it all. On the ShurVend machine vandals attacking the window doesn’t work other than the breaking the 1/8” acrylic in the window while the 3/8-inch polycarbonate maintains the security. The outside acrylic lens is cheap and easy to replace; its function is to protect the polycarbonate window. The polycarbonate, the coin slot and the bill slot are built too strong for the vandal to spend much energy trying to breech them.
In past years the usual way to add “security” to the window was to install the vendor in a wall or to install it where it is in the public view. All too often vendors that are installed in the wall can not be easily seen by customers using the vacuum island area or they are 50-100 feet away from the vacuums. In many cases the multi-vendor is installed near the bill changer for “public exposure” even though these machines do not need to be supplied with coin since they usually have bill validators installed. In either case the vendor is “Out of Sight, Out of Mind” from the customer’s viewpoint. Impulse sales are very hard to produce when the vendor is out of sight. Vending sales are not what they should be for the operator to make a good Return On the vendor Investment.
Cont'd
Cont'd
