I purchased a car wash a couple of months ago and have been chasing down a problem with water continuously running in my self serve bays ever since. Water constantly drips in 4 out of my 5 bays. If you squeeze the trigger it comes out at a steady stream. My first inclination was that it was a defective solenoid on the weep system, but after replacing the internal parts and then finally the whole thing, I ruled that out. I have spent hours trying different things and have so far only figured out that it is siphonage. I have a Jim Coleman Super Saver tank and if I hold the ss wands higher than the tank, then the flow of water stops. I also know that if I disconnect the water line anyplace between the pump and wand air is introduced and the siphonage stops. What I don't know is what I can do to fix it. I have spoken to many experienced car wash repair specialists with no luck and was hoping that someone here might be able to point me in the right direction. Thanks in advance for any advice.
