We've been having a series of problems with our 2 L4000's where we get a message stating "Auto Ret-FR Eye" in between washes. Normally that would mean that the front / rear eye is blocked during the return cycle. The exit door is held open, and it takes an extra 30sec's for the machine to reset. I've had the tech's in and they've measured the strength of the eyes, etc. and never found a cause. It creates problems, because if a car is sitting at the Access unit, and sees an empty bay with the pull forward service light on at the exit end of the bay, they will often pull in before the machine has finished resetting. Then nothing happens, then they call me, or they will back up and the undercarriage kicks on, and it's just one big CLUSTER!! On a busy day this can really slow down the throughput.
Today I find out from a very knowledgeable service tech that it may have to do with the version of software that I have on my PDQ Laser Minder. I was told that version 19.A, B, C didnt have this type of problem, but the later versions 20.?? do. I happen to have the later versions at both of my sites. He said that they could try to get me version 19.? but that it wouldnt have the obstructed arch retry feature, which is the main reason that I bought that upgrade in the first place.
Is there anyone else knowledgeable about PDQ's Laser Minder that knows about this issue? If so, can you offer some advice on the best way to remedy it? I was told that PDQ is aware of the problem, but has yet to fix the software. I'm just trying to confirm the story and find a solution.
ScottV
ScottV
