I know most low pressure systems that use PROCON pumps are gravity feed.
Does anyone know if you can pressure feed a
PROCON pump ? Something around 50 PSI, and then the pump to bring the pressure
Up to 150 psi ?
Yes, the Procons have a maximum inlet pressure of at least 100 PSI. I couldn't find anything specific with a cursory search, and it might be different between models.
I have procon on both gravity and pressure feeds. Yes it works being pressure fed. Have a solenoid valve on inlet or outlet to pump, If not you will have flow through the pump at city pressure.
