Programming Microcoin QL
copperglobe
I have a question on the Microcoin QL and it's programming. How do you delete or forget a coin you've already programmed into the QL? I don't mean just "disable" but forgetting the coin so that it's no longer in a category? I know how to enable/disable coins. I'm now using QL Talk which is the ability to program the QL via computer but it won't let me overwrite a coin that was programmed manually. Thanks.
I'm not sure you can actually do that, but you could just program a coin you already take in that position. Maybe just program a quarter there. It is my understanding that the metal content of quarters is going to change in 2018, I believe. If that happens we will all need a position for the new quarter.
