Pump out recommendation
This is another (newer) thread on pit pump outs.
I read through some of the older threads and got motivated to try to dig this out myself. I dropped a sump to drain most of the water and then shoveled three wheel-barrows worth of sludge/mudd out of the pit. At this point, I realized that with 6 bays to do, and 3 wheel barrows barely making a dent in the amount of mud, I should probably get some help.
So looking for your guys' advice on pit clean outs in North Texas/Dallas area.
Based on my measurements, my pits are around 8ft x 2ft x 6ft = 720 gallons and I have 6 of these.
I received a couple of quotes from local places, one way $1,500 a bay the other was $1.55 per gallon =$1,116 per bay.
Shoveling out the dirt bought me a few weeks of time to get this sorted, but I am hoping to bring this topic back to the top and see if anyone has newer recommendation or knows of a local company that would fit the bill.
I pay about 65-80 cents per gallon to have it done (There will always be some variables like time and distance). Find a company that currently services car washes.
$1.55/gallon seems high.
I have a septic company come and pump mine every 3 months at my 4 bay s/s for $300 plus tax, I read some of these quotes and they are crazy high . Must be different regulations for where they dump
Another option some operators do is just make a regular task of shoveling out a couple wheelbarrows each week and not worrying about completely emptying.
Agreed.
If you're not facing an impending inspection, I would attack it the same way you face an apple, one bite at a time. If you're physically able, do two wheel barrows a week hitting a different bay each time like an old typewriter.
A wheel barrow holds 60 gallons.
If your pit is 3/4 full at 720 gallons, it'll take 9 trips with your wheel barrow each bay.
9 trips X 6 bays is 54 trips (trip = a walk to dumpster?)
2 trips a week for 7 or 8 months (because they will continue to fill) would get you close to empty, fit as a fiddle, and close to $7 grand wealthier. Totally understand this isn't an option for everybody, but if you're able, this is one way to mentally plan your attack.
* Edit - How long did it take to fill up?
If you have land that you can dump the pit waste on to dry and then haul off it would be well worth it to get your own vacuum pump or tractor set up. I went 23 years with my own vac trailer before retiring it and going to my own tractor and dump trailer. 7 years ago the tractor and trailer setup cost me around 30K. It has already paid for itself many times over. I have to do my similar sized pits at least 4 times per year.
I pump out the top water with 2” pump and then use
Awesome wet dry vac. Then dump mud to dry on the side. Someone who needs soil takes it away when pile gets high. Best system I have found and we have tried septic companies and professional pit companies who make septic companies look cheap.
We recently got our first bill from a septic company as well. We decided to take matters in to our own hands. They aren't easy to find but they are out there.
We have a few locations, some of the municipalities will take it, some we will likely have to pay a disposal fee. But even with a disposal fee it'll still be a lot cheaper.
Our soil usually has some oil on it, that's not a concern for the dirt scavengers?
We have our pits tested professionally. The numbers indicated a non issue. I would not drink the water from a pit but the mud will not harm anything. 99% dirt
You do realize that the septic disposal companies around the country spread their loads across farm lands for disposal.
given the things people flush down their toilets that household septic waste is worse than the pit mud. Most septic companies do regular testing of their loads before the waste is spread but I bet in smaller communities they skip that step to save money.
This thing actually works pretty well? Always wondered how well it did.
Yes. Works well. That said we are testing a 3” mud and sludge pump (diaphragm pump)
Renting one to see how it goes as that would make life even easier. Will update thread when done with rest.
Update: I rented two different 2” pumps. The submersible trash pump was an easy to use size. Just drop in the pit. Worked for awhile then the mud seemed to be a bit much for it. Perhaps a 3” submersible trash pump would work better. May try that version soon. Both pumps are electric so you need a 100’ cord.
Next rented a 2” diaphragm pump with a 5.5 HP Honda gas motor. No name on the system so I have no idea what brand built the setup. Worked a bit better but for a 5.5HP engine it was dog slow. The submersible trash pump move liquid much faster. This pump had two hoses. A 20’ ridge hose for the intake and a flexible 50’ hose for the output side.
Next week I will rent the 3”submersible trash pump to see if the 3” hose helps the process as the submersible pumps are much easier and quicker to use. Stay tuned.
My guy charges $1600 for the entire site, a 4/2. It's a busy wash but I'm in a suburb and a relentless mud Nazi so I only have to pump out about every nine-twelve months, I like that. No equipment to store or maintain, no hassle, and I don't go home smelling like a pit.
When we started at this wash we paid $500 per pump out to a septic company. The EPA has put the fear of their dept into septic companies such that none will service a carwash. We now pay specialty firm $6000 per pump out and testing of our mud. It always comes back as just mud. This is nuts but we have no other options although we keep looking.
I asked someone at the firm why they charge more than 10x the rate of a septic company. Answer: Septic companies spray what they collect on farm land. These guys add sawdust to the mud, let it dry, and then truck it to a landfill. So draino and other cleaning products sent down into your septic tank are fine for our farm lands but pure mud from a carwash is not. Frankly both should probably not be dumped onto land used for food.
Im in the N Texas (Ft Worth) area be glad to share my contacts with you....I have 4 washes and I think the price is reasonable.
I was just shown this video of a new tool. It’s not specifically for pit pump outs, but it looks like it could be used to break up and remove debris.
Link:
