R.O. carbon tank/continuous dump
My R.O. system ( Purclean 3000 gpd) started to dump water like it's flushing itself. Problem is, it'll continually flush (dump warm water).
Took plastic top off tank. Farted around w/solenoid coils and made sure they were clean. Still dumps water continually.
Anyone have this problem before?
TIA/Waxman
Washmee
Fullservice Tunnel
Canton, Ohio
Unplug the timer that controls the flush cycle. If the water is still dumping i would think that the solenoid valve is bad. If the water stops, the timer might be stuck.
