Rain X Online application
washnshine
NY
I would like to add Rain X to my top package and wanted to know if there were any compatibility issues using this product with another company's sealer/drying agent. As I understand it from this website:
http://theadvancedgroupinc.com/systems/index.php?Page=Rainx -
you should still follow up the Rain X with a sealer/DA. Since I am not using the complete Ecolab line, I wanted to know if anyone knew of any adverse effects putting on another brand DA after Rain X.
My current sealer/DA - it functions as both, is Bead Up by Diamond Shine. It is a pretty standard high beading chemical containing mso.
Anyone else using Rain X, but not their complete chemical line? Any issues with the chemicals?
dewey9876
I CLN CAZ
I use Qual-Chem for all my other chemicals. No issues at all - Works great
washnshine
NY
Thank you. So you are doing the Rain X first, then the sealer/DA - right?
robert roman
Bob Roman
Clearwater, Florida
Bead Up contains;
Butoxyethanol – is butyl ether of ethylene glycol. This stuff is a relatively nonvolatile, inexpensive solvent with modest surfactant properties
Quaternary ammonium compound – this is “ammonia” used in acid cleaner formulations
Mineral seal oil – hydro-treated middle grade distillates of petroleum
Isopropanol - IPA is one of the most widely used solvents
Rain-X online contains;
Butoxyethanol
Acetic acid – is weak acid. Vinegar is roughly 8% of acetic acid by volume making it the main component of vinegar apart from water
1-Propanaminium, 3-amino-N-(carboxymethyl)-N,N-dimethyl-, N-coco acyl derivatives, inner salts – amino salt used as surfactant in liquid soaps (imparts smoothness to surface)
Proprietary formulation of quaternary ammonium compound
Bead up produces beading effects two ways.
1) When a solution is dispensed from an arch the drops have a negative charge. When the drops make contact with surface their charge changes the contact angle of the surface.
2) Oil mineral has a contact angle of about 80. Contact angle for most car wax is 90 degrees, Teflon is 95 degrees and Rain-X online is 110 degrees.
Consider what goes on before drying agent or clearcoat
Tri-foam – contains foam surfactant, wax or acid and ethanol surfactant
Clearcoat – most products today contain polymers and detergent range alcohol
Since Rain-X online (110) has higher contact angle than mineral oil (80), I would not apply Bead Up as drying agent or rinse for Rain-X because there is no additive effect.
I would use spot free to rinse off Rain-X.
washnshine
NY
Thank you Robert.
I was under the impression from other operators, and reading through past posts on this forum, that although Rain x beads and sheds water and lasts very well once it is applied, it may not be great for setting the car up for an immediate dry after application. I recall reading it needed a "cure time" - and the seconds that it will take to go from the Rain x arch to the rinse arch to the blower may not provide the water break that a dedicated drying agent will.
Your description of contact angle makes perfect sense, but I am still interested to see if the Rain X alone will break the water enough without another product.
rph9168
Carwashguy
Atlanta
You should actually be able to eliminate the drying agent on packages that include Rain-X if your computer will allow that. Almost all drying agents should be compatible with it especially at the rates you should be applying them. You should not need a heavy rinse after it. The cure time relates more to the Rain-X product for windows - not the super sealant.
I have been using rain X in my IBAs for years with no final rinse agent after the Rain X application other than spot free rinse water and it has always worked well at beading and aiding in drying the cars.
robert roman
Bob Roman
Clearwater, Florida
“I recall reading it needed a "cure time" - and the seconds that it will take to go from the Rain x arch to the rinse arch to the blower may not provide the water break that a dedicated drying agent will.”
It’s not cure time but time for the polymer to bio-degrade to form hydrophobic or water hating properties. Whereas some polymers are designed to bio-degrade to form hydrophilic or water loving properties.
The greater of the contact angle of element in solution, the greater the water beading.
Rain-X online has a much greater contact angle than any drying agent. So, there is no need to use drying agent after Rain-X. There is no additive effect.
However, Rain-X is like drying agent. It must be applied in properly, the cleaner the surface the better.
Many operators (I did) use a secondary rinse of the vehicle prior to applying Rain-X, clear-coat or drying agent.
There are specs for arch, nozzles, proportion and pressure that need to be followed.
Skimping/using too much Rain-X online produces same effect as skimping/using too much drying agent.
Good flush with spot-free sets up the product for good drying.
My experience when using Rain-X online along with product containing mineral seal oil is it can produce smears on window glass. When it rains, customers complain their windshield wipers are streaking. It’s the oil.
