Razor edge solenoid
cbchevy4x4
Does anybody know the brand of the below imaged solenoid? 20211211_094956.jpg
I'd be more worried about what size it is than the brand.
That's a GC valve. The white decal on the coil has the model number it. If you know size of orifice, coil voltage, whether normally open or normally closed, and operating pressure you can generally replace with most any brand. You can probably buy a replacement on Kleen rite.
Please use the money you saved to buy a newer phone or photography lessons. :)
cbchevy4x4
Thanks to those that knew the brand was just curious more than anything. I know the size and will probably go dema anyways. As for pic quality it was a picture of a copy of a manual. I cropped and zoomed the photo of just the valve in the diagram.
